1998 DeVille Executive 4.6 Northstar
I just got it been driving it 3 days had no issues until today I decided to recharge the a/c I had hot air blowing so I figured it was low went for a drive for about a half hour then it overheated with those codes no smoke in my exhaust white or black no burning oil smell or coolant and I didn't smell gas in my coolant resavoir what is the issue anybody?
Welcome Aboard !!! Which car, model, year, engine? Please update your profile.
B 1312 refers to A/C high side sensor problems; P 1483 is a generic cooling system performance code.
Bookmark this and use it to define codes when you post them. Thanks.
98 DeVille
32 litre northstar
Could it be because I did something wrong when I recharged the a/c and if so if I clear the code will it solve my overheat problem?
Lmao typo 😅
There it's fixed now help me out
B1312 - High Side Temp Sensor Open Circuit
there are temperature sensors for the refrigerant on BOTH the HIGH pressure side and the LOW pressure side -
this code means the sensor is either unplugged - or it is broken -
it IS possible that you unplugged the sensor - or knocked into it and broke it -
NO - for a couple different reasons -
first - clearing a code does NOT fix or cure anything - ever -
it simply erases the code from the computer's memory - temporarily -
and that code WILL constantly re-appear until the issue is FIXED -
second - this code points to a HVAC issue -
and has nothing to do with overheating -
regarding the overheating -
it COULD be many many different things -
and it will require a LOT more - VERY specific information - to try to diagnose the problem -
things to check -
how hot is "overheating" -
describe - IN DETAIL - the exact sequence of overheating -
does the temp raise sitting at a stop light -
does it drop when you start moving -
coolant level - when FULL - the serge tank should be about 1/2 full -
does the cooling system maintain pressure when hot -
do the electric cooling fans both operate -
does the PURGE LINE have a constant - gentle flow of coolant going into the serge tank -
if you turn the cabin temp up to 90* -
do you get really - REALLY hot air from the vents -
