1 - 20 of 22 Posts
1997 Cadillac SLS
Can anyone help me with this? It's a hazard on cold nights, because my windshield fogs up. The heater blows out cold air when I select the "front Defrost" button, and set the thermostat to 70 degrees. The rear defroster works fine, of course, and it feels like the driver's side blows out moderately warm air, but the passenger side blows out ice-cold air and fogs up that portion of the windshield.
This is simply not optimal with the colder months approaching. I think this car has had this problem before when my father owned it (or maybe this is an on-going problem that was never fixed in the first place), but I can't remember for certain, and I can guarantee he wouldn't remember either, nor would he know what's wrong. So asking him isn't an option.
Bad heater core? Something electrical, perhaps? Any ideas would be greatly appreciated, thanks!
When the windshield fogs, is the moisture on the inside or the outside ?
If it's wet inside, that's moisture from within the HVAC ducting, heater core, or the evaporator drain sump.
If it's wet outside, that's condensation of outside humidity onto the cold glass.
1997 Cadillac SLS
Probably not.
Depends on what you consider "expensive", but I'd say yes. A dealer repair will be VERY expensive.
I have a reputable mechanic here in town that knows my car and specializes in Northstar and GM cars. I'm not dumb enough to take it to a dealership.
Inside.
1997 Cadillac SLS
I found an AC Delco heater core at AutoZone. They want $125 for it.
First check the HVAC stack condensate drain fitting at the turn of the firewall to floor pan - just passenger side of center, probably hidden by a flap of soft insulation.
1997 Cadillac SLS
Discussion Starter #9
I'll check that. I also pulled out the service records from February when it was in the shop:
On page two, under "Cooling System Complete Diagnosis", it says (among other things):
-Pressure test system, leaks found:
-Thermostat operation: leaking
-Cooling fan operation: ok
-Water Pump condition: leaking (this entire unit was replaced, as was all the belts and "HD Truck Thermostat/Engine Coolant Thermostat", as well as new coolant....see details below)
-Radiator Condition: ok
-All coolant hoses condition: ok
-Serpentine belts: ok
-Heater Core condition: ok
-Coolant protection level: low
-Performed engine block test: passed
Under "water pump - remove and replace", it says:
"As per recommendation, replaced water pump and all gaskets, replaced thermostat with belts and tensioner. Refilled and bled cooling, recheck no other leaks at this time."
Make of that what you will. This was all performed on February 5, 2019.
Stay away from AutoZone "Don'tLast" parts, IF you end up needing a heater core.
Since it recently tested good, check that drain Sub mentioned first.
1997 Cadillac SLS
Discussion Starter #11
I have a membership to AutoZone, and their customer service has always been outstanding. I have no reason to stop using their services, however, I certainly won't use Duralast products.
As for the drain sub, I'll make a note of that for my mechanic. Thanks!
autozone is good for ONE THING - free tool rentals
1997 Cadillac SLS
Discussion Starter #13
Tell you what....when they screw me out of a deal, part, or treat me like shit, then I'll shop somewhere else.
Besides, at least they aren't Baxter Auto Parts....you wanna talk about useless auto parts stores.....
With moisture on the inside of the windshield (post #6), it sounds more like a heater core or a plugged A/C condensate drain.
1997 Cadillac SLS
Discussion Starter #16
To be fair, it's not that fogged....perhaps a little bit less than a quarter of the windshield on the passenger side. If I can, I'll take a picture of it and post it here.
1997 Cadillac SLS
Discussion Starter #17
Update:
So I just got it out of the shop yesterday. The passenger temp door actuator was faulty. They found good power, ground and signal to the actuator, but it wasn't moving. The mode door was working properly.
The shop replaced the temp door actuator. Now it works like a dream, and I'm willing to bet good money that this is the first time that heater has worked properly since my family bought it.
Diagnostic: $89.99
Labor Total: $217.49
Parts Total: $178.04
Shop Supplies: $13.84
Sub Total: $409.37
Tax Total: $34.39
Grand Total: $443.76
Goddamn, these things are spendy. :cry:
Now all I need is a new wheel bearing and tires. Should be fun.....😞
Update:
Diagnostic: $89.99
Sub Total: $409.37
Tax Total: $34.39
NOT trying to make you feel bad - or ripped off - BUT -
I HOPE you got dinner - with drinks - and a movie along with that SCREWING -
DIAGNOSIS -
IF the actuator WAS defective - a DTC - Diagnostic Trouble Code - would have been set -
pulling codes takes 2 minutes - using the on-board scanner -
PARTS -
the actuator - ACDELCO 15-72215 - is $75.57 - with free shipping -
LABOR-
replacing this actuator takes about 1 hour -
that includes a 15 minute coffee break -
SHOP SUPPLIES -
REALLY? - you don't even need a paper towel to do this job -
for wheel bearings -
stick with either ACDelco or TIMKEN -
FRONT -
TIMKEN 513121 - $84 - with free shipping -
ACDELCO FW293 - $103 - with free shipping -
REAR -
TIMKEN 512006 - $136 - with free shipping -
ACDELCO 512006 - $157 - with free shipping -
for tires - I recommend DISCOUNT TIRE -
great people - good prices -
1997 Cadillac SLS
Discussion Starter #19
1997 Cadillac SLS
Discussion Starter #20
$103 for a bearing that the shop wants $350 for. And lord knows how much they'll charge in labor. And the problem is, I'm not sure which bearing needs replacing (Edit: it's the front bearing, according to their paperwork). It's whichever one is giving me the traction control and brake light notices.
Sigh! I wish I had checked Amazon before I took it to a shop. Now I'm wondering how much they screwed my poor father out of when he had it in the shop before I got it.....:unsure:
1 - 20 of 22 Posts
