while it would probably FIT -
it will never RUN and DRIVE -
SO - the actual question is WILL IT WORK?
and the answer is NO WAY!
Welcome to CF !!! I changed your thread title to be a bit more descriptive of your question.
While the 1997 would fit into the engine compartment of a 2002, there's no way it would run - they're very, very different engines, wiring, ignition systems, fuel systems, calibrations, other stuff.
And if the 2002 needs an engine you would need a 2001 or 2002 Northstar FWD engine with the same VIN code (9 or Y) depending on whether the Deville is a base model, DHS, or DTS.
