1997 Eldorado, 2003 Audi RS6
I have what I had initially thought to be a loose rear wheel hub. I had already purchased the replacement, and in the process of breaking the bolts loose on the original, found what was really causing the movement. I could grab the wheel and rock it at any positions, usually a dead giveaway that the wheel hub is broken.
Anyway, I found that the upper bushing (knuckle to control arm) is actually what is worn out, and worn it is... it is very bad, clunking over bumps, and no doubt causing the rear end vibration I have had for a few months now.
The driver's side produces somewhat less of the same movement, but no clunk over bumps yet.
My question is... Does anyone have any idea what to do about this other than replacing the knuckle? I really don't want to pay $555 per side for it, or even the $400 that a local dealer offered me. The part is, according to GM, not serviceable on a 1997-2002 car, yet it is removable. On a 1994, 1995, 1996, it is replaceable. Is there a reason for this, is there a difference in the part that you can actually see? I don't have the older part so I can't look at it closely or measure it.
I would really like to find something that would fit, and I do not want to turn my own polyurethane bushing or anything like that. This is a Cadillac, not a Cobalt SS that wants to be a sports car.
This clunk, wander, and vibration really has to go.
It appears we have an identical problem, I was hoping that someone with more knowledge then me could answer your question. I brought my Eldorado to a local mechanic who didnt feel comfortable working with a 97 because it was far different then previous year models ( I dont understand it but anyway) He did give me a schematic of the problem which I hope will help you and anyone else who can offer less expensive way to fix this problem
Good Luck
CHECK OUT THIS OFFER FOR OE GRADE REPLACEMENT BUSHINGS !!
MARCH MADNESS SALE
GET THEM NOW FOR $199.00 & SHIPPING
Last Shot Auto Parts, LLC We are the LEADER in REPLACEMENT Cadillac Rear Knuckle Bushings for your car !!
They fit All Models from 1993 to 1999, and Eldorado to 2002. The Suggested Retail Price for these Cadillac Suspension Bushings is $249.00 & Shipping,and provides both Cadillac UPPER Bushings and Cadillac Lower Bushings in the Set, requiring only 1 set per Vehicle. The Bushings will enhance the ride and control and will return the car back to the Quiet, and Smooth Original Ride.
The Bushings carry a 1 Yr Limited Warranty and are Real Automotive Quality Products, Designed & Engineered Specifically to remove design failure and flaws inherent in the GM parts, and exceed the OE performance requirements for your Car !! We sell Worldwide, and provide Installation Support necessary for a Super easy Install with Instructions that are included.
You Won't Damage The Bushing Or spindle Installing these Cadillac Bushings! We Quality check the OD on our bushings and refinish the surface to closely held tolerances to insure ease of insertion, while providing a STRONG, reliable, and safe product!!
(Also we can Part Number the Product as well, as we sell more than just this part and application !!! )
For the do it yourselfer or the pro with minimal tools. We have your bushings in stock !!
Beware of Molded Plastic (Polyurethane): It squeaks going down the road ! DON'T BE MISLED !! They OFFER installation on your knuckles because certified Mechanics WON'T install them ?!! And they GREASE them so they won't squeak AT FIRST for a short while!! When the lube is gone listen to the wonderful Squeaky Cadillac !!?!! And then you can end up with this issue:
"I have a 1997 deville d'elegance. I repaired the rear knuckles......................... and used POLYURETHANE performance
bushings for the top. However after ~2500 miles, I am feeling "bumpsteer" from the rear, and I have suspect worn out upper bushings. Do you sell the uppers only as a set of 2? I would buy them from Ebay."
Thanks in advance,
John , VT
We set the standard AS the FIRST Cadillac Replacement Bushings on the market! We have PAT PENDING on our products for a reason!! All the rest are cheap imitations so why would you want to pay twice ??
Customer responses: see our "feedback" section from customers)
"I can't tell you how thrilled I am to have these bushings available. I had them installed and what a difference in the handling and ride on my Deville. Your excellent customer service, and going the extra mile is refreshing in todays business world.
Thank you!"
DAVE , Iowa
Hello, I just wanted to say how grateful I am to your company... as those lovely folks over at Caddie don't carry them as a replacement part…… Your help when I needed it via phone was immediate and accurate. You set the bar for outstanding customer service. These are tough times and most of us are tightening our spending…….I will recommend your product to any and all caddie owners with the same very common problem.
Thanks again,
Mike , IL
1994 Cadillac Eldorado Touring Coupe
Uhh.. Usually when you spam, you want to post to something recent.
Not something from 2007.
