1 - 10 of 10 Posts
1997 Deville
Need some advice on how to remove the rear wheel/ ju bearing assembly!! Have it stripped down but having trouble removing hub itself any advice??? All I've been able to dig up is remove the bolts and then it says remove Hub lol, doesn't seem to be that simple on my 97 North Star deville 4.6 thanks in advance
There are special procedures needed to remove/replace the hub assemblies.
Don't risk breaking something - subscribe the car to www.alldatadiy.com
2010 DTS
:hmm: I've replaced a rear once, but don't recall any difficulties or special procedures. :noidea:
1997 Deville
Yeah like I stripped braking down and turned the flange and took the four 10 mm bolts out and then i figured it would just come out u know like it doesn't have the splines like the front so idk I'll give it another whirl tomorrow maybe see what happens
96 Concours, 05 DHS
At the four ears/corners where the bolts go through, I think the hub casting angles slightly away from the knuckle juuust a tiny bit and you might be able to get the tip of a chisel in to spread them further apart. Some PB Blaster beforehand might also help.
1997 Deville
Thanks I did already spray down with pb blaster I saw the tips there I will get at it with a chisel and let u know how it hows
1997 Deville
Discussion Starter #8
Update pb break loose and sum good ole love taps worked great also the chisel was extremely helpful thanks to all came out great jus wanted to make sure I wasn't missing something thanks again
2010 DTS
If you have compressed air available, a pneumatic chisel can be a Godsend. Saved my ass several times.
1 - 10 of 10 Posts
