Is there a seperate fuse for the washer pump on a 1997 DeVille
I am not hearing the pump work when I try the washer switch
Common failure???
Thanks in advance
Bob
1998 Deville D'Elegance
Look on the pump to see if there is a wiring harness you can remove then connect 12v to the pump and see if it runs. Don't think there is a seperate fuse, in fact I think it's a circuit breaker for the wipers along with a fuse??
