When the car is cold for about the first 10 min of driving the gauge cluster lights & gauges are in-op. They come on and go off. None of the gauges will operate nor will the test lights, or the interior lights. As a matter of fact the only thing that does work is the radio, but not able to control it from the steering wheel. After the car warms up it works fine. Last night when all came back on and settled down I was not able to turn on the fog lamps or the high beams. The high beam indication was working but the lights never changed to high beam.
Thanks for any help
Tom :banghead:
Can you pull any codes? It sounds like the BCM is having power issues.
I did check for codes and there were none. I am leaning towards checking on the headlight switch/twilight sentenel. I have had some luck getting the gauges to come back on by switching the head lamps on & off several times. Not sure if it was a fluke or if it really worked. I will try again the next time it happens. I will keep you all informed.
Thanks for the input
Tom
About this Discussion
2 Participants
IFixAircraft
