I get clicking,,, Used auxiliary battery jump start battery with 800amps lasted,about 35 mins.Cables are clean and tight, - lights go out At turning up the key,, Could the security kill switch in the Cadillac STS be kicking in ? And how do I check thatWhat happens when you attempt to start it? Dead silence? Clicking? Lights go very dim?
Have you put a DVM on the battery? What is the voltage, both static and while attempting to start?
Battery cables clean and tight?
=====================I get clicking,,, Used auxiliary battery jump start battery with 800amps lasted,about 35 mins.Cables are clean and tight, - lights go out At turning up the key,, Could the security kill switch in the Cadillac STS be kicking in ? And how do I check that
================BEFORE you do anything make sure the battery is good. take it out and take it to a parts store and have it load tested. Your jump pack will NOT over come a bad battery
