My car was running great. drove to work when I tried to start to go home, it started but shut off in a few seconds. The driver information center said anti theft came up and may not start. It would start but shut off right away. After getting it towed home, I tried starting it again. Same problem. After connecting my scan tool, it says it can't connect. I read that the PCM OR EMC might be the problem with many things going wrong. Like traction control, abs, cruise control. Before this all happened I had service emission system. I had time to work on the car. I replaced intake gaskets and many other things like purge solenoid, charcoal canister, well eventually it was the a clogged catalytic converter replaced it, like I said since then the car ran great. Now it starts then shuts off the transmission shift lights all flash at the same time.
Does anyone ever have this kind of a problem?
Are you able to pull the DTC's via the onboard diagnostics? Might be a clue there.
I cannot pull anything information from my DTC. Nothing seems to work from rhe DTC or form my scan tool.
It sure sounds like a PCM failure. I would probably play with the battery connections and grounds first to make sure that all looks good. Then unplug the PCM a couple times to see if anything changes. If nothing changes I guess I would try another PCM.
Long shot, but you might also try pulling both battery cables and touch them together in a sort of reboot.
