1 - 9 of 9 Posts
1996 Sedan Deville 4.6l v8
I need the location of the blower motor resistor. Blower motor won't shut off after turning off car and removing key. I have to manually disconnect blower under the hood.
the blower motor speed controller is built into the blower -
it is NOT serviceable or replaceable -
you can spend around $250 for an ACDelco unit online -
or about HALF that for a FOUR SEASONS 35121 -
Thanks for the reply basscatt. The blower motor can be controlled at different speeds. I installed another I had in a previous 96 and did the exact same thing wouldn't shut off. So I'm thinking it's a burnt out resistor as I've read this blower motors have constant power.
There are three leads on the blower motor. Ground, 12volts, and a modulated signal to control speed
With the HVAC buttons set so the blower is off, there should be no voltage on the grey lead at the motor (the middle wire)
thank you for the reply harry yarnell. I see so there might be a short somewhere given that i tried two blower motors and both would not turn off.
It's a common problem with these integrated motors. It's POSSIBLE you have two bad motors.
My concern here is you say you can vary the speed with the ignition OFF.
once again - THERE IS NO RESISTOR -
ALL of the blower functions are controlled by the built-in electronics -
not shutting off IS a fairly common failure of these blowers
1 - 9 of 9 Posts
