OK, my security system keeps thinking someone is trying to open a door and closing it.
In normal operation, if I stop say at a stop sign or the side of the road, keep it running and in gear, and use use the power lock button on the door to unlock the doors, then Open the driver's door (or any door, but I can't reach the others), as soon as I close the door, the car will lock the doors as part oth the auto locking. This can be shut off via programming the remote, but I kept it functional
While driving, I get a light show, courtesy lights flickering, and eventually the doors will try to lock, but they are already locked. If I use the power locks to unlock the doors, I still get the light show and eventually the car will lock the doors.
So it is thinking that someone has opened a door.
I CANNOT find any door pin switches. The only thing I note is a small round black circle about 1/3 inch diameter where a pin switch would go. There is one on each door. It does Not appear to be a closed off conduit opening. Those would be larger and there is one higher up on the driver's door (I didn't check the other doors).
Do these cars use some passive / magnetic / other sensor to detect when a door is open or closed??
OR - is the security system black box, the one that on on the rear package shelf under the panel - which I had replaced because my old one went dead - gotten FUBAR'd already??
If so,what is the remedy to get the de-posses the car's security system??
