!996 DeVille
Hello,
I'm trying to removed the complete broken power antenna and am not able to removed the bezel on the outside. Is there any suggestions on how I can remove this old antenna so I can get the replacement installed?
Thanks!
2010 DTS
Welcome :wave:
If I remember correctly, there is a slot in it? If so, use a screwdriver & hammer and gently tap the bezel around to loosen it.
You don't have to remove the bezel. Just unbolt the antenna from inside the trunk and pull down.
To remove the bezel you need the right size socket to fit over it. It's plastic and strips easy.
Well a lot of years did use the kind with the notches on the back fender. I think 89-93 had those.
