I'm experiencing a crank, but no start on my 1996 Cadillac Deville. The car was running previously and it stalled in traffic out of nowhere to which it would no longer start again, I was able to get it towed back home. I checked the fuel pressure when turning the key to the ON position, not START and it goes up to 10psi and then drops to zero within about a second. I am also not receiving any DTC codes pointing me to any issues. From my research I found that 3 of the main problems could be the fuel pump, fuel pressure regulator, or the fuel filter.
I am looking for some help and some tips to help me further my investigation into pinpoint what the actual problem could be.
Any ideas?
2010 DTS
Your fuel pump is D.O.A.
Factory spec's are 45-50 psi. While it will run at somewhat lower fuel pressures, 10 psi won't do it. To add insult to injury, the pre-2000 Devilles did not have an access panel, so you are in for a tank drop.
How certain are you when saying it's the fuel pump? Also, is there any tests I can do to check if it's the fuel pump specifically?
Any ideas?
I agree with Ranger - faulty fuel pump -
fuel pump/fuel pressure is NOT monitored -
the fuel pump
BINGO -
the FPR - Fuel Pressure Regulator is vacuum operated -
IT uses engine vacuum to REDUCE fuel pressure from the fuel pump to the injectors -
or the fuel filter.
a clogged/restricted fuel filter would reduce the VOLUME of fuel being delivered -
with the engine OFF - you would see "normal" fuel pressure -
when the engine started - the pressure would immediately and dramatically reduce -
99% - assuming you checked the FUSE and it is good -
you could up that to 99.99%
if you probed the wiring harness at the fuel pump with either a test light or a DVOM
YES - exactly what you already did - with the fuel pressure gauge -
