96 Concours, 90 Deville
One of my fiber optic lines must have come loose that displays the status of the taillights. Does anyone know exactly where the fiber-optic lines are run? I need to see if maybe one end of the line was knocked loose. As of now I only have one of two indicator lights working. The taillamp is definitely not burned out. I tested them both and they both work fine.
The first place to check is the tail lamps themselves (because it's the easiest), then check the roofline indicator. They are usually off at the lamp. They fiber cables run down the rear sail panels into the trunk.
So can I check this just by removing my rear taillight lense?
