1 - 2 of 2 Posts
1996 SLS
Ok Guys Have fun with this one..I kind of inherited this car along with these problems..
Check Engine, Traction Control and ABS lights stay on all the time. How do I reset these codes? Also on dash warning (ie) Check engine oil, low coolant scrool across even those these levels are all fine.
Any help would be greatly appreciated.
Joe
2010 DTS
See the sticky on codes. It will tell you how to pull them and clear them, but be advised that any monitored component that fails will reset the DTC and illuminate the MIL again.
If you are getting low fluid warnings and the levels are OK, then the sensors are bad.
1 - 2 of 2 Posts
