1995 Fleetwood tow wiring harness
507 Views 1 Reply 2 Participants Last post by  dirt_cheap_fleetwood
I have a 95 FWB with the factory Tow Package V4P, only 39k.
Question:
This car has the wiring harness located
in the trunk. Do I simply hard wire the
harness to the 7 way connector? Or do I
have to use a powered converter or
Modulite? Apparently there is not a
T-One connector available for this car.:confused:
Also, for the brake controller, is there a connector under the dash for this?
Or do I hard wire it too?:confused:
Thanks,
1 - 2 of 2 Posts
You will have to do some serious wiring to get a brake controller. There should only be four wires in the back which are for the lights only. You will have to hook the brake controller into power (a circuit that is only live when the ignition is on), ground, the brake pedal switch and then run the wires to the rear of the car. Unless someone already screwed around with it, then you have to do some investigating and figure out what they did.
1 - 2 of 2 Posts
