1995 Eldorado
I previously reported a radiator issue. The Caddy dealer in Yokosuka advised there is a plastic drain mechanism at the lower right area of the radiator, and that the plastic piece has deteriorated, causing the leak/release of coolant. As I stated before, the coolant flows out perfectly from a small factory-hole under the radiator. The dealer recommends replacement of the radiator, $1,700.00. Really need some assistance. Otherwise I will sell this car, with 53,000 original miles. Can the plastic be replaced without replacement of the entire radiator? Any experienced advice is appreciated.
Scott
:banghead:
1995 Eldorado
Ranger,
Can you believe the labor involved? I wasn't a math major but...if the petcock costs $5.00, and the most expensive of new radiators $150.00, the Cadillac dealer intended to charge $1,545.00 in labor. I'm taking a photo of the condition of the radiator/petcock tonight, as I 'have' to assume a corroded radiator loosened the fitment of the pet cock which then dislodged. What do you think?
Scott
:bomb:
· Super Moderator
2010 DTS
Considering the age, that is possible. That labor fee is excessive. I'd ask them to break it down and justify that price. You might have some competitive prices with you. I suspect the hourly fee might be a little embarrassing.............. then again.
That's an impossibly high rate, if you know what you're doing (or have done it several times in a few month span ;) ) and have small hands it takes less than an hour to replace a radiator. Dealers I have found want $700-800 for a GM OEM radiator. You should be able to find one at an AutoZone with a lifetime warranty (the plastic side tanks on all these radiators crack eventually) for $250 or less when yours go. Until then, stick a new petcock in there, The last time I tried that though it didn't work because the actual housing developed a leak. Your other option would be to remove the radiator, drain it, let the housing dry out, JB Weld up around it and put the new valve in...
Once you go through patch fixes with the parts on these cars you'll realize the value in simply doing the job right the first time and replace the one part you need yourself, cause replacing or removing the same part 3 times in a month is a PITA and to let someone else like the dealer do it for you will result in some serious pain in the wallet...
