1995 DeVille 4,9, mocha , canvas top, gold kit, mocha pearl interior.
Ok, so the left upper "bushing" or joint is so worn as the emergency brake doesn t work ( the whole weel moves),
original part number 18023709 with two screws on each bushing seems to be discontinued 20 years ago, replaced by another,
Question: to me it seems as if the 97-99 type 18026760/59 would also fit, according to gmpartsonline it says "1993-99" but in fitment
it says 1997-99 deville.
Anybody with knowledge on this?
Reason: of course they re all discontinued, and aftermarket bushing does not fit for the original one that is still on the car, now also worn into the knuckle metal i suppose,
only the later so will have to replace whole wheel setup
Discussion Starter #2
I'm gonna go ahead and answer myself, No the 97-99 have cut out of rear fender so probably different wheel position.
And there are different versions of the knuckle left side rear, so no way to push out the bushing on at least the version my car had
Solution: eldorado is the same 93-98, and check pics of scrap yard part, no screws (two lower two upper) through the knuckle to secure bushing (or maybe grease points) then will work
