1994 Sls
1994 SLS: Dashboard lights work, but speedometer & all other dash & digital doesn't
I just bought this 1994 Cadillac SLS that is obviously hurt for some passionate TLC.
The main problem here is that my gauges don't work. Any of them. the speedometer, RPM and gas gauge light up but nothing happens.
The digital read outs on both sides. don't work ether. :nono:
Also the radio does not work. Not sure if this is unrelated or not.
Any info would be greatly appreciated as I am on a pick-a-part budget here. :crowded:
2000 STS
Re: 1994 SLS: Dashboard lights work, but speedometer & all other dash & digital doesn
Check the ignition supply voltage at the connectors of the cluster. At C2 Pin A2 brown wire and C1 Pin C13 pink wire.
Also check the ground at C1 pin C16 and C2 Pin A5 black/white wire
2002 STS/ 1994 STS
does it start? Are you able to obtain any codes? Is the battery any good?
1994 Sls
Thank you very much for your help. I have one more question about your answer. Can you give me an idea of how I would check that? I am not familiar with it, or a link to where I can see it explained.
Once again, thank you very much for your help.
Everything else seems to be fine. The car starts and runs great. I just don't know when I will run out of gas and how fast I'm going. I am also missing out on some of the great features of this car. Lol
It does have a check engine light on. I have not got a chance to check them being that I bought the car 7 hours ago and it's still dark here. Sun should be up soon.
2000 STS
Originally Posted by LittleNo Check the ignition supply voltage at the connectors of the cluster. At C2 Pin A2 brown wire and C1 Pin C13 pink wire.
You need to remove the instrument cluster from the dashboard to get access to it's electrical connectors at the back. Then you measure voltages/continuity as I said before.
However, if you don't understand how to use a multimeter, you better let the job do someone who does. There are not so many reasons for your problem, but without any knowledge it's getting a bit hard, may be too hard.
F
Guest
Im having the same problem with the 94 deville i just bought, spedometer lights turn on but no information input to them so i have no idea how fast im going
1998 deville
I have a 98 deville having same issues except my climate control and my gas mileage I can read other than that the whole panel is blank. I would love to know what you come up with on how to fix the problem or if I find out I'll be more than happy to let you know. For me though up to this point it's been more than irritating trying to figure it out.
