1994 SLS
So I am replacing the MAP sensor which is bad. While I'm there though I figured I needed to replace the little thin gasket under the top cover that goes around the intake plate. It looks like all the injectors are attached to it and I need to remove them and unclip everything from this gasket.... what a pain! Can anyone verify this is true? Vehicle Auto part Car Engine Automotive super charger part
2010 DTS
I can't answer your question, but from what little I can see. the gasket appears to be in good condition. If so, don't replace it.
1994 SLS
Unfortunately the little grey gasket was actually pretty flat and I tried to pry it up and it broke so now I'm having to by the entire gasket assembly which is much bigger than just the gasket. They call it a gasket but it is that entire black piece.... grrrrrr.....
When all else fails, read the GM/Helm shop manuals ................ :hide:
eBay ............. :duck:
