Hi i got a 93 Seville with a 4.9 gm as a donor car , a 90 VW Jetta Diesel donor car and I have a 94 Seville sts with a 4.6L .
the 94 is in immaculate shape besides the fact it has a cracked block . I am having issues trying to find a replacement block or engine
so i have a couple options. the diesel swap is actually pretty straight forward but involves me dumping around 4k in to the car for a adapter plate and a transmission controller . I could put the 4.9 in although I not sure but would assume swapping of ecu, tcu and wiring harnesses. im from south western Ontario and I would really just love to find a 4.6 for it … or if anyone has a decent compatible engine swap please enlighten me . I just wanna get this beauty rolling
Swapping in anything other than another 4.6 (93/94) will most likely be a massive undertaking, mainly due to wiring, sensors and the PCM not being compatible, not to mention that the 4.9 and 4.6 use different transmissions.
I wouldn't even know where to start with a diesel, ESPECIALLY if it came out of a VW.
The 4.6 - from the same year/model - is the answer. The other jury-rig swaps would be true nightmares.
Talk to Jake at www.northstarperformance.com. Ontario, Northstar engine builder.
unless you have Jay Leno kind of money -
you'll need to stick with a 1993 or 1994 Northstar motor -
if you ARE going to do some sort of engine swap -
might as well go with a 500+ CID and make it rear wheel drive -
Apparently I misread post #1. Post #2 corrected.
