I just recently had water pump timing chain and distributor cap replaced and now my car shake it started small like a smalll shake but now it shakes as soon as you put it in drive or reverse
1992 fleetwood w/4.9 engSounds like a rod knock. shut it off for 10 minutes,start-no knock.drive 1 mile knocks again.same over and over. cad mech said front main bearing! can that be?
1967 Cadillac with a 429 how do the brackets mount to the alternator? Just had motor rebuilt and installing and can't figure out how the brackets onto the alternator??
I'm leaking gas from engine when it sits also I have little power when I hit the gas. Im not sure if it's just a bad O ring or if it's the injectors themselves. If it is the injectors any tips on replacing them and any recommended injectors?
So i just got this 1967 cadillac eldorado in a trade, rear window is rotted out and electric needs help.
when i got it id didnt run so well, so I did a standard tune up, well still runs like crap and had a buddy to a compression test and he told me i need to rebuild the motor.
now thats fine but...
