1 - 2 of 2 Posts
2007 DTS
My service engine soon light appeared briefly this morning on my 1994 devile. I ran the diagnostic mode on the panel, it it showed a code "PO44". It also showed a PCM? which I don't understand. What can I do to correct this problem with the O2 sensor? Replace the right O2 sensor.
"PCM?" is asking if you want to enter the PCM mode.
Before replacing the O2 sensor, look for a vacuum leak that would affect the right bank.
1 - 2 of 2 Posts
