1 - 8 of 8 Posts
I replaced the A/C compressor in my 1994 Deville a couple of years ago. Recently I replaced a water pump that had been leaking. I believe that all of the anti-freeze and water that was sprayed into the engine compartment may have built up a film on the A/C clutch and clutch plate so that it engages but slips.
The A/C "works" in that it gets cold, but it only does so when the RPM's of the engine are up. As soon as the RPM's fall the air from the vents goes humid/warmer and eventually has no cooling at all.
I put a guage on the low pressure port without the clutch engaged and the engine running the pressure was ~140psig. With the clutch engaged the pressure was not much different, maybe about 135psig. However, the air that came out of the vents inside was cooled when I rev'd the engine. In fact, when driving on the freeway, condensate forms on the passenger side window by the A/C vent due to the coldness of the air coming from the vent. Due to this, I believe that the compressor is still working just fine.
What would be an acceptable clutch and clutch plate cleaner? I do not want to mess up the lubrication in the clutch or compressor bearings etc. Before I look at more serious repairs, I believe that a good cleaning of these contact surfaces is in order.
I was thinking that brake cleaner might work. Is there a way to spray soapy water between the clutch and plate? Maybe a mechanical cleaning of the surfaces would be better...
I'm open to ideas or other thoughts.
PS Sorry about the "book" long post.
94 ETC,97 STS
The clutch may be worn out. Just like a drive line clutch wears out. I've had that happen.
Brake cleaner should be fine. It's made for brake linings which are similar to clutches.
I vote for the brake cleaner as well. That said, your problem sounds more like low refrigerant or a condenser clogged with dead bugs aside from the high low side pressures. Was the compressor an A/C Delco or afternmarket? Was it new or rebuilt? Maybe it is failing and the orifice tube is getting clogged with compressor debris.
When I recharged the system with refrigerant the pressure was around 140psig. So I do not believe that the system is low on refrigerant.
The new A/C unit was an aftermarket NEW compressor. I would hope that I would get more that 18-24months. However, if the clutch isn't slipping, it may be the belt slipping...
Thanks for the help! I'll give the brake cleaner a try.
140 PSI is WAY to high for the low side when running. It's rather high even for a static pressure. If it is the belt, your alternator, P/S pump and water pump should also be slipping.
97 Cadillac deville
Okay so if the clutch was slipping you would see smoke? White smoke how much smoke? Does this apply to a 97 caddy deville compressor also? I do have a bad noise coming from that area when the heat or ac is on. I think its my clutch. But the a/c works fine. Pretty good and cool.
1 - 8 of 8 Posts
