great story, one you posted a world record 9 times
Best Car Insurance | Auto Protection Today | FREE Trade-In Quote
IF you can find one thats at a reasonable price. I refuse to overpay for low mileage, especially since these cars need to be driven on a regular basis. I think the geezer suggestion is actually more important, as are the service records. Id be suspicious of a 94 anything with 20000 miles on it, and there beterr be proof its not just because it was driven 20000 hard miles in 2 years and then shoved in a garage after someone died to fall apart.b. buy an older car with 20k or 30k on it, especially if you have the maint records.
Good luck.
Because when you put the car in park the RPMs raise for just a moment due to the load of the driveline being off the engine, then the engine settles back down into a normal idle. It also idles at a lower RPM once you put it in gear, which will really make any engine abnormalities particulatly present.aside from speculation on how i should have gone about purchasing my car (where is this pessimistic anger in all of the other "my car has problems" threads???)
would you guys pin a rough idle and/or rpm jumping to the a/c freezing/thawing
i do hear a certain fan noise when this problem occurs
what i can't figure out is why putting the car in park stops the problem, if only for a second or two
Unless your car is specifically labeled "Premium Unleaded Fuel Only" like the 4.5 and 4.9 motors, it should be able to cope with whatever you feed it.also, does running 89 have any affect on how the sts would idle?
The N* has always been a 4.6 - but in later years they cracked the code on how to get them to run on any octane. My 99 STS does not have the "Premium Unleaded Fuel Only" label on the gas gauge. My 90 CDV with the 4.5 did have the label. So in theory I can feed the STS anything 87 and above and it should run without problems. However, if yours says it on the dash, that's what you should feed it. My bet is still on the ISC as your problem though.'tis labeled
but i thought the northstar in the STS was a 4.6?
