1 - 10 of 10 Posts
Hi all, what is the expected MPG for a 1993 Sedan Deville? My car has 114,000 miles and is getting about 14.5 MPG on the highway. I just put new spark plug and wires in it and there was really no change. Thanks.
1993 DeVille
I have a 93 4.9 with 110k. I got 27 mpg on my recent trip from Fla. to NY.
A lot less around town with the a/c and tunes on.
Showing any codes? Any mods?
No check engine light or anything; No mods. I will have it checked for any codes; Thanks.
You can pull the codes yourself via the onboard diagnostics.
14.5 highway is very low. Like sonjaab said, you should be in the high 20's.
93 SDV, 06 DTS, 2010 STS, 18 CT6
Definitely a problem. My 93 with the 4.9 does way better. Good YouTube videos detailing code readings.
1993 sedan deville
My 93 Sedan Deville with 4.9 gets 23 avg according to the digital display. For a lead foot in NH. not to bad. Small town small cities and rural hilly driving.
my 1995 Deville with the 4.9 ALWAYS got 28.3 mpg on the 400 mile trip between Minneapolis and Chicago -
PREMIUM fuel - AC on - cruise set at 74mph - speed limit then was 65 -
Discussion Starter #9
Wow; yes definitely going on with mine; I drove Houston to New Orleans (~350 miles) and back last month and I got 14.5 MPG tops; That is with new plugs, wires and checking the timing; It's been this way for a while; I will pull the codes and try cleaning the throttle body. Thanks.
my bet would be failing fuel injectors -
if they are the originals -
the up-dated BOSCH - 4-hole injectors WILL make a difference -
$100 - for a matched set of re-manufactured BOSCH injectors on ebay -
1 - 10 of 10 Posts
