1 - 9 of 9 Posts
Stock, untouched radio setup. All of a sudden the new (at the time, 2016) ACDelco battery would go dead after sitting over a weekend. Did a draw test by pulling each fuse and found no reading after pulling the radio fuse a few years ago.
The power antenna no longer operates without the radio fuse in place, but I still have light reception and the in car unit still functions. The antenna did not run or buzz after going up or down when it was still operational.
I'd like to have my radio back, but I'm not sure if it's the power antenna, the trunk unit, or what actually is the problem. Any ideas on how to diagnose and troubleshoot further would be appreciated.
Let's start here, do you even meter, bro?
81, 87 and 95 Fleetwoods, 89 Brougham
You will need same easy procedure to find your draw. If you do suspect your radio, replacing it is no big deal. A friend of mine had the "eject" button on his radio malfunction, and it would pull a little less than 1 amp at all times, and it damaged the battery. Good luck!
Do you do the test at the fuse block, or at wiring harness?
Sent from my Nokia 6.1 using Tapatalk
As far as finding the draw itself, testing was done at the battery. Pulled all body fuses (MIN fuse panel on driver's side dash) until amp reading went to zero.
Beyond that, I need assistance as to diagnose any further. There's a used radio unit in a 68,000 mile car sitting in a salvage yard with front end collision damage, but I'm not much for buying parts without knowing a part is the culprit.
Knowing what fails in these radios helps too. Several people "rebuild" them, so there are fixes as long as you know what you're doing.
Best way to proceed is to remove the radio from the dash. Is the power drain still there?
1995 Fleetwood Brougham
After reading these posts a couple more times I realized, I do not think my radio has an electric draw on it, it really only work when it wants to, and if it doesn't then it won't work at all.
The LED will always light up, but when it is acting up it will not power off even when the knob is turned, volume will not change, and radio stations can not be changed. When the car is turned off it will power down, but when it gets cranky it just goes crazy. And it is cranky more often than not these days.
1980 FBC
Sounds pretty much like my ex-wife.
1 - 9 of 9 Posts
