1993 Fleetwood Brougham 6 door
I just purchased a 93 Deville for the fun of it.
The Fuel Data center and Hvac displays do not light. Somone suggested the radio may be the culprit since a delco from another model
was in the dash. The factory head unit was in the car, I reconnected it, and the clock display works. but the FDC and Hvac control still have no
display. It was also suggested the bcm may be bad on this car. Before i begin throwing parts at it, I would like to test the pin on the bcm that goes to
the two displays. After that background, I am looking for the pin that i need to test, and maybe the wire color.
Also any other ideas as to what to look at if the pin has power. the harness to the radio is unmolested.
BCM was the problem for my 93 Fleetwood. Same symptoms
I think when the BCM fails you get a "c" or "d' in the display. You may have a problem with the display units. We used to have hundreds of threads about this. If they are still here you can research the specific symptoms.
