1985 DeVille 4.1 gas
my car has a E53 code with a slightly rough idle but only when your sitting at at light or in park when driving it is not noticeable, i cleaned the connectors that go to the ignition coil and did a quick inspection of the coil cleaned the battery connection at the battery another interesting note is the car runs smooth when you first start it up but when it gets to operating temperure and you turn the car off and then start it that's when the idle is rough i have a general knowledge with car repair i did see the ignition coil which seems simple to change should i start with that, thanks
Happened to me as well. Had to replace the pigtail to the distributor.
thank you for that information what pigtail gave you issues there are to quick disconnect connections on the outside of the distributor one with three wires and one connector with one the connector with one wire i noticed has some insulation missing right underneath the connector i have a ignition coil coming I'm also going to change that but i will give the wires a further inspection
