1991 cadillac fleetwood brougham
i replaced my digital dash with a used one. everything works on the display but the speedometer is stuck reading zero. any advice on repairing this.
Yes the old one did it also before it went out. So you dont think its the speed sensor on the transmission.
I also have trouble code that reads 119. Can you tell me what that code means.
Thanks.
Did the old one do that? If not there's probably something wrong with the new dash. Try unplugging it and plugging it back in, it probably won't make a difference tho.
My post was about your dash problem.
If your old one had the same problem it's probably the speed sensor or the box for it under the dash. If the old one worked fine there's something wrong with your new cluster.
