1 - 16 of 16 Posts
Banned
Super smooth ride. Lots of power and torque with the trusty 4.9 L.
I've only got 31,000 miles, but it has needed nothing except a radio fix due to a faulty circuit board. There are stories on this Forum of cars like mine getting 150,000 miles with no problems other than routine maintenance. There is one with 279,000 miles from this forum and the 4.9 was still running strong when I last talked to him!
If these cars are maintained and cared for they shouldn't be much of a risk if you pick up an older one.
Things to watch for might be the air shocks in rear, and make sure the coolant was changed often along with the supplemental GM pellets/tablets.
Premium Member
Ralph. Can you do me a favor? I just added this to my original post in this section:
Please specify "pros" and "cons"..
I think you probably already covered the pros but if there are any cons, please note them..
Thank you...
Banned
Not much for cons that I've experienced. I suppose a MILD shake sometimes at idle, but very mild. It's my understanding the Northstars run smoother but it doesn't bother me.
The only other con for now that I can think of would be for the Lexus driver parked next to me envying my classy fins and skirts that are non-existant on any new car today. :shhh:
Here is something from one of my first posts I forgot about:
"The 4.9 sure has good power. I cannot believe it is only rated at two hundred horse (cannot remember the RPM) Has anyone else experienced leaks? 10 years ago (under warrenty) my dad had to get new oil seals and a tranny pan seal done. At least it sounds like is a pretty reliable engine overall, and thanks for all your past input."
1989 Fleetwood Brougham d'Elegance|2018 Chevy Colorado Z71
Ralph, you mentioned the GM coolant with the pellets, does the 4.9 have a problem with warping like the HT4100? Why does it need the pellets?
Banned
If I'm not mistaken, the pellets help to seal the engine so coolant doesn't eventually get into the oil. If GM recommends it, for the 5 dollar cost of the pellets, I have no problem doing it. I don't recall reading anything about warpage on the 4.9, I think they got it right by 1991. The 4100 had that problem.
Banned
Discussion Starter #8
I guess my heater core is plugging up possibly because it sits alot and it wasn't winter driven until last year for the first time. (moderately, I might add) It's taking a long time to get any heat.
The coolant was changed a few years ago with the long life orange stuff, I added the supplemental tablets last year. I think even in the summertime, I'll occasionally run the heater to keep coolant flowing through the core to possibly help prevent sediment from plugging it. Just like how I run the AC for 5 minutes a month in winter to help keep the AC seals conditioned from lack of use as recommended in the Chilton's service manual.
I don't know if the "T" fitting can plug up or not but its never been touched.
Banned
Discussion Starter #10
Not too impressed that GM doesn't stock much in the way of parts for my car now. Last month I needed an upper rad hose and the ONLY one available in all of Canada had to be ordered in from Ontario! I know that it is getting old, but I can get a rad hose for a 1980 Pontiac anywhere, even the corner auto parts store.
At least the heater core was very reasonable at $100.
1991 Sedan deVille 4.9L/1994 Lincoln Town Car 4.6L
Dunno how old the post is, but the sealant pellets for these cars are required because the aluminum heads are porous, which means that they can 'sweat' coolant. The pellets dissolve and add a 'layer' of material to the inside of the heads to prevent them from doing this.
The pellets are required because the 4.x series of engines use aluminum heads that are porous and can 'sweat' coolant. The pellets dissolve and add a layer of material that prevents this. They also provide corrosion protection for the rad and other parts which isn't an unwanted benefit, for sure.
Banned
Discussion Starter #13
hi all, well this car has still been very good, it is running great and only 52,000 miles I think. The automatic headlight sensor crapped out a couple of years ago and that cost 500 dollars, the brake master cylender had a leak and the oedal went to the floor and I finally changed the original Michelin tires after 18 years to Goodyear Regatta 2's and all 4 were defective after only 3500 kms, so now it wears Assurance by Goodyear.
peace
Banned
Discussion Starter #14
peace
oh I forgot to mention that the CCR light came on a few months ago and stays on but I'm not worried about it, when I had the tires off I noticed mild fluid loss from the front shocks, kepp on truckin
ralph its now october 2014. Could you please leave an update on your 91 fleetwood. How many miles,what repairs have been made,was it all expensive,any major repairs,trans,motor,etc!! Looking forward to your reply thank you!!
Banned
Discussion Starter #16
Hi Nick. Well it has 122,000 KMS (you will have to convert) and it has been pretty good except last year was a brutal one. II had to get new seals on the passenger side CV axle and for some reason the head gaskets decided to fail. (Apparently they are steel) and my coolant was getting contaminated with oil. So after a $2500 repair bill for new head gaskets alone at the local GM dealership I still had to go back THREE times because they were trying to save $ and using thinner Felpro head gaskets (where the heads meet the block) and was getting lots of smoke pouring out of the engine while driving. Im went to my hometown mechanic while visiting my family and they confirmed that it was the dealerships fault, and where the smoking and leak was coming from) Anyway each time they had to fix it they CONTINUED to use the thinner Felpro gaskets and the same thing kept happening. On the second attempt the mechanic was removing the fuel rail and some gas spilled onto the exhaust manifold and he singed his eyebrows, and burnt his face! This is no joke, and the other mechanics started nick naming my car "Christine!" Anyway the service manager FINALLY admitted they were NOT using GM gaskets (which are a LOT thicker) and the problem seems ok for a year now.
1 - 16 of 16 Posts
