1 - 2 of 2 Posts
1992 Sedan Deville
Hi I recently drove on a long trip where I was losing coolant and the caddy ended up overheating. I tried to pull over as soon as it did. Now when I pour new coolant in it leaks out rapidly from behind the engine. The leak ultimately comes down through between the trans pan and the oil pan. I tried to get under and look up but couldn't see where it was coming from. Am I dealing with a cracked engine block or could it be a fix worth my while? Dipstick shows normal oil no milkshake look. Didn't see anything on water pump face of serpentine area. Any help would be much appreciated. Thanks
NOPE - can't see a thing from here either -
doubtful -
well - since the car can't be driven as-is - MAYBE -
depending on the overall condition of the car - and the actual cause of the leak -
get it to a regular shop and have them pressure test the system -
it MIGHT just be a blown hose -
1 - 2 of 2 Posts
