ELC system symptons.
1. Turn the key on, the compressor does come on after 45 seconds and then shuts off after about 3 seconds.
2. Loading weight into trunk the compressor does not come on.
3. If I remove ELC Height Sensor Link and move the lever manually the compressor does come on.
4. When the compressor is running the shocks do not inflate.
My next test would be to remove one of the air lines and see if the compressor is pumping out any air.
However reading up on this system, it would seem the shock bladders are leaking, probably due to age, and won’t raise the car.
Question; are there any more test to pin down the problem? I have also read that if the bladders are leaking the compressor will run continuously, mine doesn't.
