1 - 10 of 10 Posts
Discussion Starter · #4 ·
Katshot said:
Check your mail. It's on its way.
Thanks katshot i need the wireing digram for down in side the distributor where the pickup coils are one of my wireing plugs came apart for the pickup with no pig tail three wire i need that digram if you can help thanks again i think the wire are one red one blk an one brown
Discussion Starter · #6 ·
Katshot said:
As I recall, if you look at the bottom/right section of the diagram, the actual distributor wiring is there too. You'll see the module, pick-up, coil, etc. That should be everything.
Yes Kevin i see it but the copy is real fuzzy i cant make out what its says is there a web url for this or is it a copy out of your book thanks again for all your help [email protected]
1 - 10 of 10 Posts
