1 - 2 of 2 Posts
1990 fleetwood
a/c heater fan never turns off, even when the key is off. tried changing the bcm , it didn't help. any one with suggestions?
larry
'87 SDV
It's the blower control module. Common failure item. It bolts into the top of the plenum on the firewall under the hood, just about in the center. I believe the plug is L-shaped, or possibly is two connectors that make up an L-shape. You can use a junkyard part to fix it, but buy two just in case you get a bad one. Should be able to get it at a U-pull for around $10. Easy fix.
1 - 2 of 2 Posts
