I'm leaking gas from engine when it sits also I have little power when I hit the gas. Im not sure if it's just a bad O ring or if it's the injectors themselves. If it is the injectors any tips on replacing them and any recommended injectors?
The '90 - '95 4.* liter engines are equipped with a sequential Port Fuel Injection (PFI) system. The Sequential Port Fuel Injection system replaces the Throttle Body Injection (TBI) system used in previous years. The PFI system replaces the two injectors in the throttle body with eight injectors located in the intake manifold. There is one injector above each intake valve. A fuel rail distributes fuel to each of the injectors.
1992 fleetwood w/4.9 engSounds like a rod knock. shut it off for 10 minutes,start-no knock.drive 1 mile knocks again.same over and over. cad mech said front main bearing! can that be?
1967 Cadillac with a 429 how do the brackets mount to the alternator? Just had motor rebuilt and installing and can't figure out how the brackets onto the alternator??
So i just got this 1967 cadillac eldorado in a trade, rear window is rotted out and electric needs help.
when i got it id didnt run so well, so I did a standard tune up, well still runs like crap and had a buddy to a compression test and he told me i need to rebuild the motor.
now thats fine but...
Okay, so my 429 has a pretty significant coolant leak. It appears to be coming from around the water pump, so I'm going to be replacing some parts. Namely the water pump, hoses, and thermostat.
My question is, there appear to be two options for water pumps on this engine. A 1 Inlet and 2...
