1 - 19 of 19 Posts
NONE- yet...
Hello everyone :)
I'm looking forward to getting my first Cadillac. I found one for a pretty good price of $800 down the road from where I live. It needs a fuel pump, a battery, and a new windshield if I wanna pass inspection. It's cracked from left to right- sadly. It's been sitting for a year or so but is in MINT condition. Anyway- that was just some background info. So like in the tile it's a 5.7L V8. I went on google out of curiosity to see how much horsepower that thing has (expecting something in the 300-400hp range), while all the sources list it at 175-185hp! Big surprise... My old Infiniti has 200hp on a 3L V6! How is all that horsepower limited?? How to get rid of that limitation?? Those are my two main questions. If I'm to have a V8 Caddi I really want to let it breath not have it restricted to the max. Afterall those things should be able to go up to at least 300hp I suppose it's all probably all of the emissions restrictions but professional opinion would be greatly appreciated.
Thanks,
Jake
1996 Fleetwood
From what I found, in 1990, I just see a 5.0L V8 with 140 horses, 255 torque. However, that site could be wrong. The reasons for such low power, 1, it's a low compression engine, likely in the 8:1 ratio. 2, the heads and intake aren't designed to flow high volumes of air, they're designed to keep the engine smooth and quiet. 3, the engines just aren't tuned to create a lot of power. However, be comforted by the fact that the 5.0L and 5.7 from GM both have loads of aftermarket support, so you should be able to beef up the engine for cheap. One thing to remember when doing it though, in a vehicle that size, torque means more than horsepower. My 96 Fleetwood is only making about 310 horepower, but the torque it's generating is closer to the 400 mark, which is why I run a 14.6 in the 1/4 mile and have a 60' of about 2.2. (Pretty lively for a car with a race weight of 4840.) To make more power on your car though, first thing is a freer exhaust, then a freer air intake. Those 2 alone will probably give you 10-30 horsepower and similar torque. (Depends on how choked down they are on a 90 Brougham.) After that, you have to decide how much more you want and how much you want to spend. An 8:1 compression is a nice base for forced induction, but an engine almost 20 years old, that can be a problem. Just plan ahead.
· Auto Enthusiast
1992 Eldorado Touring
Hello everyone :)
Thanks,
Jake
These cars were not aimed for speed or agility, the customer base wanted a smooth comfortable ride with some torque.
The TBI motors of that generation are very restricted. A TPI setup would open up some HP and get you over 200. The Vortec heads are also another option.
Go over to some of the third generation fbody forums and ask around. There are plenty of ways to get good power out of a SBC.
1990 Cadillac Fleetwood Brougham
Stroke it out and throw some good flowing cylinder hads on top. Top it off with a set of headers and some computer work. The possibilities are endless. It just costs money to go fast. Like was said before, check over on the thirgen.org site.
NONE- yet...
Thanks for the replies. I figured a turbo wouldn't be such a bad idea- a double turbo. The car has 96000 miles on it. If I want to add more power (torque that is) I'm gonna have to rebuild the engine first and follow that with rebuilding the transmission too. First things first. The exhaust will be taken out as it's all covered with rust anyway. I'm gonna make a custom one myself. I could add high compression pistons but than the turbo is a no no. I think I will rather go with the turbo after the engine is rebuild.
I don't wanna start another post so I'll just ask here if it's a good idea to swap the tranny to a manual. I've been driving stickshifts all my life and I just love them. If I could swap a good tranny in instead of rebuilding the automatic, it would be great. A lot of work but well worth it. The questions is what tranny to put in there that will go together with the engine hehe.
1996 Fleetwood
I would not recommend a stick if you plan on dumping a lot more horsepower in. Manuals give nice power transfer, but they're not quit as durable, and especially so in a vehicle the size of a brougham. If you're determined to go stick, look at the corvette sticks, and plan on overbuilding one of those. As for slushies, the 700R4 is a stout tranny, especially when built up, and it mounts to many 350's and 305's.
I would go with a super charger versus a turbo set up. With the turbo you will need to be pretty knowledgable with tuning your car. Why not put a big block under the hood? If your looking for torque a big block will put a big smile on your face.
Past: 95 Fleetwood, 91 Brougham. Now: 92 Lexus SC300
This is what I would do . . . .
Provided that your existing TBI 350 is running great, doesn't use oil, and passes a compression check, keep it. Put some vortec heads on it, change out the intake to better flowing aftermarket unit, add some long tube headers(ones made to fit a 1980's caprice work), get a true dual exhaust, change out the cam(even a very mild cam will net good gains) and change the TBI to a carb. This will get you at least 300 hp, for about $2000 in parts.
The real benefit of keeping the 350 in place is you keep all your acceories the same and the a/c will still work.
Unfortunately, I got the 307 5.slow motor in mine. I'm going with an LS1.
Ls1's are awesome. I had a 1999 Camaro with the LS1/auto combo. Even though I was just intake/exhaust, it ran a [email protected] The powerband was awesome on that motor, lots of torque down low, just explosive from 3k to the redline at 6k. Mine made 305rwhp/320rwtq.
NONE- yet...
Discussion Starter · #11 ·
Some time has passed and I fixed the Caddy up. The fuel pump is replaced with a new one. Im working on the rusts spots. The engine runs great. It will be rebuilt some time when I have more cash handy. Im looking to rebuild the engine, transmission, and the back so I can dump some 500hp and similiar toque in. That should really make my day. Now its time for the sound system, good clean up, and sweet red interior and exterior neons :)
P.S. For double charge what compression ratio would you suggest?? I was thinking about high 8.
Hello everyone :)
Thanks,
Jake
I've had my 1990 Brougham 5.7 since 2000 and I've been the sole driver and maintainer. The low horsepower is the result of very low compression, a very limp cam profile, throttle body injection and emission devices that are just dismal. But I can get true 21mpg on the road at max 70mph. It drops the faster you go like most cars. As far as getting more horsepower, don't bother. By the time you change the cam, add some compression, get vortec heads and port injection you can replace the engine with a new Chevy crate engine and get any horsepower range you might want. BTW it's a Chevy engine anyway so no real loss of originality if that matters to you. Besides, as is, it's an ultra smooth engine that can propel the car to any luxury speeds up to low 100's mph which is clearly not recommended. It is not meant for that. But... with a removal of some of the emission stuff you might be able to add a small turbo kit and add about 100 hp without destroying the silky smooth driveability. But engine life will be shortened based on how hard you push it. The short of it, there's no easy way to make Grandma's car into a hot rod without major work. Still I love mine and it's completely original. I hope you enjoy yours as much. Oh one last fact, adding a better stereo system is a real bear since the engine control computer is behind the stereo and limits the installed depth, and wiring around the power module to get to the speakers wiring is non standard for a car from that era. It can be done but do your homework before you begin. I hope this helps a bit.
· Administrator
Welcome to CF !!! You just posted to a 10.5 year old dead thread, and the quote poster has not been in here for the same time - 10.5 years.
LOL. That's what happens when you are as old as I am. I am now the newest and oldest official noob on the block. Thanks for the heads up. I was looking to find some people still driving the old beauties. I saw that post and remembered thinking the same thing when I first got mine. I will try to be more alert to dates and current issues.
The 1990 5.0 is the Olds 307, which is a dog. The 1991-92 5.0 is a Chevy 305. And the 1990-1992 5.7 is a Chevy 350. Yes, the stock HP is 175-185 on the 5.7. I think it has to do with year and whether is is a California emissions car or not. In 1990 the 5.7 had 175 hp. In 1991 and 1992, it had 185. The 1993 Fleetwood retained the 5.7. But in 1994 it was replaced with the 5.7 LT1 with 260hp.
Please keep posting i searched and found your info very helpful, just purchased a 90 d elegance with the 5.7 thank you
Hey, nice to meet you! I started out a fast boat sailor out of Hawaii on the Sante Fe and Greenville, shore duty in Bangor Washington, followed by another shore duty in Newport News Va then the USS Maryland out of kingsbay GA, and then a small stint back on the USS Greenville in Hawaii ......than Civilian life in Florida/Georgia. I joined the navy in 95 and did 15 years
· Administrator
Fun & games !!! I went in in '58, did 2 diesel boats, 2 fast attacks, 4 FBMs, SUBFLOT 8 staff duty in Naples, Italy.. COB in 2 of the missile boats. QMCM(SS)(DV) My time was all East Coast - New London, Charleston - retired as Command Master Chief, Naval Academy, Annapolis. Just missed the big moves to Kings Bay. I see that you're near JAX now.
Plenty of 90s Cadillac and 5.7 owners here. You should have no problem keeping it fit and healthy. Best of luck. Maybe some info in the Engines forums, too.
1 - 19 of 19 Posts
