1 - 8 of 8 Posts
the transmission on ''D/drive'' goes on neutral after stopping, only with high rpm goes abruptly into drive again.
Work's ok when you select the 3rd gear.
I am looking to buy the car, but it has this problem.
What could cause this?
Thanks.
More detail please.
  • what is "hook",
  • will it work In 1st on cold start?
Sounds like the transmission is slipping into limp mode. Might be a loose wire in the harness on outside or inside that is disconnecting resulting" solenoid defaulting into 3rd gear.
Pull codes to see if there is any confirmation.
1984 Eldorado Biarritz
Sounds like a linkage problem to me. An '89 does not have solenoids for shifts, rather a cable for shift points with vacuum modulator for shift feel. If there's no slop in the linkage there is internal trouble which basically means a rebuild.
Oops, my bad, need glasses, thought it was a 99 seville.
Discussion Starter #8
Ok.
I will add that: when it goes out of gear and comes on with revving the engine, it goes into gear abruptly.
1 - 8 of 8 Posts
