1 - 9 of 9 Posts
1989 Cadillac Brougham d'Elegance; 2000 Cadillac Deville
I'm getting around to rewiring my Cadillac and I don't really want to deal with the thing. The motor, carb, and trans were all replaced and don't need the computer anymore. Is there anything else the ECU controls or can I just get rid of it.
'84 Eldorado and Seville
Almost sure it controls the engine RPM when the A/C compressor is engaged. When the dash control signals on a A/C call the blower motor control module and dash control signals the ECU which checks the A/C compressor cycle switch and if the A/C compressor is needed the engine RPM is increased and decreased when it dis-engages.
1996 Federal Heritage Hearse
On the 307 the ECU controls the carb and distributor. You say you replaced the carb. Did you replace it with a non CCC carb? The distributor will need to be replaced with non CCC unit.
The entire engine was replaced with an olds 350 from the 70s. No computer control.
'72 Eldorado Convertible, '97 Eldorado ETC, '93 Fleetwood
An '89 Brougham with the power to get out of its own way . . . what a concept 🤣
Discussion Starter #9
Exactly. Had to fight myself not to get some sbc mounts out of a '90 and some adapter plates and go with a turbo 5.3 ls instead.
1 - 9 of 9 Posts
