1988 Coupe Deville, 1991 Coupe Deville, 1989, 1994 Eldorado
Hello
My Head Gasket Went The Other Day And I Wanted To Know If Fixing It Would Be Worth While.. It Has 188,00 Miles On It But It Ran And Looked Mint, Oil Was Changed Every 2,000 Miles Not A Bit Of Rust On It, I Used To Get 25 Mph On The Highway With It. There Was Also No Warning .. It Happened Over 2 Days. :( When I Drained The Oil Out, There Was A Total Of About 11 Qts.
WITH ALL THE EXTRA FLUID, COULD IT HAVE DONE ANY ADDITIONAL DAMAGE TO THE ENGINE?
Wanted To Know If I Should Go Ahead And Fix The Head Gasket Or Put A New Engine In It?
Where Can You Get A Reman. 4.5l
Jim
1989 Sedan DeVille is now just a fond memory ....
If the eingine ran great up until the head gasket failure and there is no physical damaged to the engine components, i.e. cracked or warped heads then I would consider replaceing the head gaskets and keep that engine going.
Different car, different engine but, my 88 Mustang 5.0 blew a head gasket at 225,00 miles. I repaired them and it is still running strong today with over 315,000 miles.
If you want to replace the engine with a re-build you can do a search online for them.
Well I was told that it may be the intake manifold and not the head gasket... I I will have to have it tested to see, Is that a test I can do myself
thanks
