1 - 9 of 9 Posts
1985 Cadillac Fleetwood Brougham
Hi I have a 1985 Cadillac Fleetwood Brougham. Does anyone know how to replace the front and back turn signal bulbs? I can't find it anywhere online or in the manual. Please and thank you!
1979 Coupe deVille, 1995 Sedan DeVille (sold)
I don't think they changed the name to Brougham until around '87.
In '85, you could buy a FWD Fleetwood or a RWD Fleetwood Brougham.
For front turn signal bulb, reach up from underneath, find the bulb housing and twist it 1/4 turn counterclockwise to pull out.
Then yeah maybe it's the RWD Fleetwood Brougham, and okay thanks I'll give that a try
bigm57ict said:
I don't think they changed the name to Brougham until around '87. In '85, you could buy a FWD Fleetwood or a RWD Fleetwood Brougham. For front turn signal bulb, reach up from underneath, find the bulb housing and twist it 1/4 turn counterclockwise to pull out.
And what about the rear turn signal, same thing?
Discussion Starter · #9 ·
Alright well I'll check it out. I was thinking I'd have to do a lot of unscrewing with tools I don't even have at the moment
bigm57ict said:
I can't remember now if you can get to it from beneath. You may have to go from above with the hood open. Rear is probably accessible from underneath
welp, I replaced the bulbs to try to fix the non-blinking issue and they still won't blink. Have any suggestions? I replaced the flasher relay too.
1 - 9 of 9 Posts
