That price seems a bit under the norm.
Mind if I ask what shop you are getting this quote from?
A car as old as your Eldorado would sure need sound deadening mat such as Dynamat, Aurilex, Roadblock, Audimute. The labor to install that alone would eat up most if not all of the quoted labor. I honestly think at that labor price they will be cutting several corners.
When I put a full system in my F150 back in 2001 to install the head unit, 2 amplifiers (one for the subs, and one for the components) 6.5 components for the front, 6x9 for the rears, sound deadening, Capacitor (used to provide a more stable power signal and take the load off the alternator and battery) and all the associated wiring it took a full 8 hour day.
Granted you are not going to that extreme I can promise you that you will not be happy with the sound quality if some form of sound deadening is not installed, and if a capacitor is not installed its very possible that you will start to see alternator failures, batteries with a very shortened life spam and other electrical issues.
Have you ever seen a car with a semi powerfull sound system and noticed that with every hit of a low frequency (Bass) the lights dim? If so that was because the audio system is drawing more amperage than the vehicle is capable of supplying. And that is where a capacitor comes into play, 1 farad per 1000 watts of system power is the recommendation.
