While I was Changing my Alternator a couple weeks ago I must of ripped this off by accident, I cant for the Life of me see where this goes. If someone could point me in the right direction and possible give me a diagram or a page number in the Final Edition Manual for these hose configurations.
Thank you Caddy Heads
'84 Eldorado and Seville
The top port has no hose connection. I checked both my Eldorado and Fleetwood and they are the same, no hose connection. The port is left open.
1984 Eldorado Biarritz
Yup. From the factory it would have had a small papery filter element over it. Not needed, it is just the means by which the solenoid can vent the EGR valve to atmosphere to get it to close.
In this photo it sort of looks like a wad of foam. I did not know that. The parts catalog doesn't list the separate filter.
578092
Tim, believe it or not AC Delco does actually offer the filter as a part number. Slightly different from original, this is just a small rectangle or sponge with a circle in the middle that slides over the nipple.
The only one I can find is GM part 1977796 or AC Delco 219-14 and those are a rectangle foam piece.
I would think it would be pretty simple to fabricate one.
