Hello i have a squeaky pulley on my accessory belt but only for the first few minutes after i start my car, is there a lubricant that i can try to spray on it, the belt tension assembly and belt are brand new
Treatments or dressings are usually not recommended for serpentine belts. If the belt(s) is(are) aligned correctly it(they) should not squeak - spray with clean water at idle - did the squeak stop ? If so, I have no advice. If it kept squeaking, that points to a pulley or idler. There may be 3 free-wheeling pulleys - a tensioner, maybe a direction change idler, and the A/C compressor pulley, clutch turned off.
