1 - 2 of 2 Posts
1985 DeVille 4.1 gas
hello my 1985 Cadillac wont start i checked the relays and fuses they seem to be fine i can hear the fuel pump running however it sounds like it might not be getting fuel i removed the air cleaner and cranked the car i dont see any fuel coming out of the injectors i was running great last week and have a new battery one last thing if you fill the tank up it leaks slightly until the fuel level drops and its been doing that for a couple years must be the gasket at the top of the tank, any ideas would be great
Moderator edit: Identical threads, identical posts merged and condensed. No need to double-post. Sub.
codes are meaningless without their DEFINITIONS -
and no one has them all memorized - or remembers OBD1 codes -
dump a little gas down the throttle body and see if the engine runs for a few seconds -
check the fuses -
1 - 2 of 2 Posts
