1 - 13 of 13 Posts
1985 Cadillac Fleetwood Brougham
I've replaced the bulbs, replaced the flasher relay, but the right turn signals still won't blink as they should. I've done everything I can think of, have any suggestions? Please and thank you
ROMAN.IMPERATOR said:
What exactly did you do before this started happening? Also, the front AND rear signals must have good bulbs in order to flash correctly.
I just bought this car and it was already like that. And I replaced the bulbs with brand new ones to try and fix the problem but it didn't solve it
84 Coupe w/500
I was asking to help with diagnosing the problem. Your new flasher is not working or isn't getting enough power to flash. If all the lights that blink are in working order and you can turn the blinkers on manually, I'd say to get an electronic flasher. They flash based on time instead of heat. They are cheap enough to take a chance on buying without losing much money if it's not the problem. Not sure what it could be of the electronic flasher doesn't work.
Ahh okay. Yeah I might've replaced the wrong one. I didn't know there was two flashers
1 - 13 of 13 Posts
