Needing to replace my inner AND outer window sweeps. I see Fairchild makes the outers but do not see an inner set. Any body else performed this replacement and with what mfg?
JB, I ended up putting my old ones back on. They weren't really in bad shape, just figured I'd change them while I had the panel off. Sorry. Others have mentioned that they were able to find replacements that work-maybe just a different vendor? The difference between the coupe and convertible will likely be in the rear window sweeps.@smokuspollutus do the convertible ones work for the hardtop Biarritz? Ordered some that were for coupe and specified Biarritz but did not work.
Good to know JB, thanks!@smokuspollutus i ordered the covertible set off of eBay from a company called repops and they worked! Came with interior sweeps and staples for attachment. Completed driver side and looks so much better!
