I have a 1983 cadillac seville with the Ht-4100 i just got it it ran beautifully then it just started popping timing was off so i set it still backfire then i changed the fuel filter...then i checked the fuel pressure which was fine so it can’t be the fuel pump...What can it be?
1984 Eldorado Biarritz
Bad cam, check the oil for coolant. If no coolant you can still salvage the engine, take the drivers side valve cover off and see which valves aren't moving.
