If you haven't done it already, it's probably a good thing to check and clean all the electrical connectors associated with the cruise, as well as the vacuum lines. My unit had a vacuum line that was off.
The shop manual says for "erratic engagement and/or unwanted program acceleration" to check for "severed engage switch harness in column", or "open circuit in yellow wire at connector."
It's probably something simple, either a wire or vac line. The trick is finding the right one. Check your fuses too.
