1979 Coupe Deville
I have a 1979 Coupe Deville, The sunroof quit working on the previous owner. Can someone give me some information on what to change and where to look in the car to get this sunroof working again? The parts store is clueless.
Need to know if when using the switch, you hear any sunroof motor noise? if so then either the motor gear is stripped or the cables are broken. Also check the driver door edge for a decal stating its an aftermarket unit. Rather a rare factory option back then. Most were aftermarket by American Sunroof corp or ASC as its now known. Have you checked the fuse??
1979 Coupe Deville
When I hit the button it does nothing. I do not have a fuse diagram. I do not have a good view of the fuse panel to see what everything is. Someone mentioned a fuse relay and sunroof motor to me. I have no idea where either is located to swap out. I will check the label to confirm who put it in.
